Εδώ,
http://www.volvoclub.org.uk/pdf/VolvoOi ... 07UKv5.pdf
μπορείτε να βρείτε το τύπο των λαδιών και τις προδιαγραφές που προτείνει
η vovlo για το αυτοκίνητο σας.
dvolvo έγραψε:Lubricants, engine
EU
C30, S40 (04-), V50, C70 (05-) Engine Service interval (km) Volume (liters) Grade Viscosity Part number
B4164S3 20.000 Approx. 4.0 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B4184S8 10.000 Approx. 4.3 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B4184S11 20.000 Approx. 4.3 ACEA A5/B5 SAE 5W-30 31316299 , -300, -301
B4204S3 20.000 Approx. 4.3 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B4204S4 10.000 Approx. 4.3 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B5244S4, Model year 2004-2007 20.000 Approx. 5.8 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B5244S4, Model year 2008- 30.000 Approx. 5.5 ACEA A5/B5 SAE 0W-30 1161711, 719, 726
EU C30, S40 (04-), V50, C70 (05-)
B5244S5, Model year 2004-2007 20.000 Approx. 5.8 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B5244S5, Model year 2008- 30.000 Approx. 5.5 ACEA A5/B5 SAE 0W-30 1161711, 719, 726
B5254T3 20.000 Approx. 5.8 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
B5254T7 30.000 Approx. 5.5 ACEA A5/B5 SAE 0W-30 1161711, 719, 726
D4164T Model year 2005-2009 20.000 Approx. 3.7 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
D4164T Model year 2010- 20.000 Approx. 3.9 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
D4204T 20.000 Approx. 5.5 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
D4204T2 20.000 Approx. 5.5 ACEA A5/B5 SAE 5W-30 31316299, -300, -301
D5244T8 30.000 Approx. 6.0 ACEA A5/B5 SAE 0W-30 1161711, -719, -726
D5244T9 30.000 Approx. 6.0 ACEA A5/B5 SAE 0W-30 1161711, -719, -726
D5244T13 30.000 Approx. 6.0 ACEA A5/B5 SAE 0W-30 1161711, -719, -726
USA and CDN
C30, S40 (04-), V50, C70 (05-) Engine Service interval (km/miles) Volume (liters) Grade Viscosity Part number
Petrol 12.000/7.500 Approx. 5.8 ILSAC GF-4 API SL / ACEA A1/B1 SAE 5W-30 1161754, -755, -756
Rest of the world
C30, S40 (04-), V50, C70 (05-) Engine Volume (liters) Grade Viscosity Part number
B4164S3 Approx. 4.0 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B4184S11 Approx. 4.3 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B4204S3 Approx. 4.3 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B5244S4 Approx. 5.8 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B5244S5 Approx. 5.8 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B5254T3 Approx. 5.8 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
B5254T7 Approx. 5.8 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
Rest of the world C30, S40 (04-), V50, C70 (05-)
D4164T Model year 2005-2009 Approx. 3.7 ACEA A3/B3/B4 SAE 0W-30 1161830, 831, 832
D4164T Model year 2010- Approx. 3.9 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
D4204T Approx. 5.5 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
D4204T2 Approx. 5.5 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
D5244T8 Approx. 6.2 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
D5244T9 Approx. 6.2 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
D5244T13 Approx. 6.2 ACEA A3/B3/B4 SAE 0W-30 1161830, -831, -832
Oil grade ACEA A3/B3/B4 can be replaced with ACEA A5/B5, not the other way around.
12/2/2010 Print
..δεν δεχετε λεει η αμερικη υγρα ή τροφιμα οποτε δεν αναλαμβανουν...Περιμενω απαντηση απο blackstone...
johnkyr έγραψε:με τι το έστειλες ΕΛΤΑ ? τελικά το δείγμα ....
για να δούμε και τα ACEA A5
vrestas έγραψε:Τα sport pedals ηταν για δεξιοτίμονο
, ενώ αυτό της θερμοκρασίας νερού είναι κολλημένο στην μέση, για μια μεγάλη θερμοκρασιακή διακύμανση
, ας το καταργούσαν και να έβαζαν μόνο φωτάκια μπλε/κόκκινο ...... johnkyr έγραψε:Δεν είμαι ειδικός, αρκετά παιδιά στους 4Τ, έχουν ασχοληθεί πολύ περισσότερο.
μια καλή αρχή είναι εδώ http://www.bobistheoilguy.com/forums/ubbthreads.php
Zeus, θα μπορούσες να ποστάρεις κι εκεί τα αποτελέσματα, για να πάρεις καμιά πιο
"σωστή" ανάλυση από πιο ειδικούς (φαντάζομαι, το δείγμα που πήρες δεν ήταν από το φίλτρο λαδιού ?)...
vrestas έγραψε: You may keep the incorrect pedals!
johnkyr έγραψε:volvo 0w30 A3 σε volvo 0w30 A5 κατάλαβε διαφορά προς το καλύτερο.
θα δείξουν οι αναλύσεις ..... ότι και να λέμε ....
vrestas έγραψε:Γιαννη δωσε μας το σχολιο σου για τις αναλυσεις λαδιων. Οκ διαβάσαμε τι λεει το εργαστηριο αλλα πες μας και 2 κουβεντες αφου εισαι ψαγμενος στο θέμα.Ποσο στοιχιζει να γινει η αναλυση και ποια διαδικασια ακολουθησατε?thanx!
johnkyr έγραψε:αλλά δυστυχώς περιοριζόμαστε στο ότι υπάρχει στην Ελληνική αγορά.
Μέλη σε αυτήν τη Δ. Συζήτηση: Baidu [Spider] και 18 επισκέπτες
